Results 1 to 9 of 9
Thread: Temperature Sender Alternative
    Senior Member setho's Avatar
    Dec 2012
    New York
    My '66 911 has a 2.7L engine from a 1977....
    When I purchased the car, it had gauges in it from a 1968 911. The temperature gauge never worked.
    I've installed a set of restored green face gauges and the temperature gauge seems to run backwards and spikes.
    I believe that VDO changed the polarity of the senders at some point around 69 or 70. The older style senders are well over $200.
    Are there any alternative senders I can try out before pulling the gauge and having it updated to work with the newer style sender?
    Seth O.
    ESR #2474
    1966 911 - '77 2.7L Hot Rod
    1967 Pontiac Bonneville - '70 455
    2000 996
    WANTED: 1966 Transaxle 229835-902/1
    Oct 2010
    Southern Ca.
    The polarity of the sending units was not changed , but sometimes the gauge needs to be calibrated to work with a particular sending unit .
    May 2006
    CT
    I have early temperature sending units. PM me for details.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Dec 2010
    Southold, NY
    Read Post # 2 in the refernced thread for a primer on different sending units: http://www.early911sregistry.org/for...erature+sender
    Dec 2012
    New York
    Thanks for pointing to this one....
    So the polarity didn't reverse, but the resistance direction did, which actually makes more sense, as it's a single wire and the sender case itself goes to ground. I had bought a 1K pot during lunch, so I was already headed this way.
    A little work to do tonight.
    Seth O.
    ESR #2474
    2000 996
    Apr 2004
    35,000 ft
    the guy who installed the gauges really should have done this for you.
    Dec 2012
    New York
    For those following along....
    I measured the existing sender to ground, and it's wide open. I didn't bother starting the car and letting it warm up to see readings.
    Then I hooked up a 1k pot between the gauge wire and ground. Adjusting the pot to the different temperatures I got:
    Gauge Temp / Ohms
    140 = 183
    120 = 175
    100 =160
    80 = 148
    60 = 130
    So it looks like I definitely need the old style sender.
    Seth O.
    ESR #2474
    2000 996
    Dec 2010
    Southold, NY
    This bulletin is for a 912. I'm assuming same change was made for the 911 sending unit:
    Dec 2012
    New York
    Replaced with an original (2/66) temperature sender. Nice to see the gauge working properly.
    Seth O.
    ESR #2474
    2000 996
