Thread: Dansk Fuel Tank or Porsche
    Hep required please...
    The time has come to replace the fuel tank on my 1967 911
    I have a choice between a Dansk and Porsche (about a $1000 difference)
    Can anyone tell me the difference is in terms of quality and authenticity?
    Mar 2016
    U.K.
    Hi,
    For my '73 I went with Dansk. The quality is fine but the unions at the back are at the wrong angle so require adjusting. Not sure if the same would apply for '67 but I would expect so.
    Kind regards
    Gitesh
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    dansk tank has the slanted flat surface on the "spare wheel bubble"..not correct for 67 also the diameter of the breather tube is not 67ish
    dont`t know how correct the porsche part is ---did`nt even know that they are available
    I have a 66/67 tank. PM if interested.
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    1132 honda snowblower
    member Jackson Hole Ski Club
    Has nobody ever purchased or seen a new Porsche fuel tank ��
    Quote Originally Posted by Toffynose View Post
    I am pretty confident that PORSCHE likely does not continue to offer a fuel tank specific to 66/67, but rather one that will fit - with some modifications - a wider range of years. If PORSCHE tells you that the PN they offer for a 66/67 is the same PN for a 69-73 tank, then my guess is correct. If you don't have a good, reliable PORSCHE parts guy, let me know...I do, and what his answer is will be correct.
