Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 906 Flywheel
  1. #11
    Jan 2011
    Sunny Southern France
    Here's one with the grooves on the back : http://www.magicsix.de/schwung906e.php
    Homologation paper for the 906 states 3.565 kg for the flywheel (8.8 kg with the clutch)
    Olivier
  2. #12
    Here is what I put together based on specs from a sports purpose flywheel. I have a feeling this is what you would find on a T/R or R originally. Weight is 9.5lbs / 4.2kg. Would give a little more weight than say a 906, better ability to drive on the road or in a rally setting.
    Comparing the original flywheel with the machined version you can see the edge chamfered section is machined further and meat taken from the back then grooves added.
    Gordon may have more firsthand info from the Rs he worked on.
    Thanks, Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
  3. #13
    Here is the R one Brad copied. The holes are a little different drilled on the circumference, production flywheels just had wider spacing.
  4. #14
    This might be of some help understanding the 906/911 parts, its from the Sports Purposes outline, p13 (1968).
    Ernie W
    member of Early 911S Registry
  5. #15
    Sep 2006
    La Quinta
    Thanks for the info, Ernie!
    Here is the 906 one I have in my car. I was changing the disc. You can see one holes in the pressure plate. Interesting I have never had a problem with it in the car.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
Tags for this Thread
