Thread: 911t struts
    911t struts
    I’m replacing the mis matched struts on my 71 911t
    I’ve acquired a set of Boge p/n 911 341 044 02 & 911 341 043 02 struts
    What inserts will work in these struts?
    The bottom mounts for the ball joints are different than what’s on my car, they are not split and the holes are not tapered. What kind of bolts/nut should I use?
    Do I need to change my lower ball joints? To what?
    Thanks in advance for any help!
    Dan
    The Boge was kind of the universal strut, all the brands will work in a Boge strut. Check with Paragon in Corpus Christi for shock information. Starting in 72 the strut ball joint attachment changed to a wedge pin arrangement. You'll need the tapered pins, and the the ball joints with the 'vee' groove in them.
    May 2006
    CT
    Dan
    I have inserts, ball joints and the wedge pins for these Boge struts. PM me with your email for details.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
