Thread: Experience with 915 Factory Short Shift ?
    Senior Member swisscheese's Avatar
    Jan 2003
    The Netherlands
    has anyone experience with the factory short-shift set for the 915? Have read about WEVO, Weltmeister, Rennshift, etc., but no comments on the factory type.
    thnx. Tom
    911S 1973
    Early 911S Registry #176
    Senior Member Peanut's Avatar
    Aug 2012
    Florida
    Tom,
    Not sure if this is answer you seek, but I have a factory short shift in '86 Carrera 915. The transmission was allegedly rebuilt, but I must say the non-short shift 915 I've driven was a bit smoother in my non mechanical mind.
    Scott
    1968 911S
    1986 Carrera
    2006 Carrera S
    Aug 2011
    Eugene, OR
    My former '84 Carrera had the factory set installed in it when I bought it. The shift action was notchy and high effort. I also had great difficulty adjusting the coupler so that it would shift well into 3rd and 5th but also have the reverse lockout work correctly. The sweet spot for everything working correctly was very small.
    After removing the kit and reverting to stock, shift effort and overall action was much better, and I really did not notice that the shifter travel was all that much longer. I was much happier with the stock shifter, and will not convert to short travel shifters in the future.
    - Arne
    Aug 2012
    Florida
    Quote Originally Posted by Arne View Post
    Great feedback. The shift from 2-3 is exceptionally particular.
    Scott
    1968 911S
    1986 Carrera
    2006 Carrera S
    I’ve always liked mine, the throw reduction is only 30% or so. Adjustment of the linkage May be the cause of some of the problems cited above.
    Aug 2009
    SF Bay Area
    I've got a factory short shifter that I removed from a 86 Carrera. Yup, it is bit ticklish to adjust but works great. Some of the aftermarket short shift kits, not so much.
    Jim
