Results 1 to 1 of 1
Thread: Help needed
    Mar 2018
    TN USA
    Help needed
    Hey folks,
    Would someone mind checking, on a 65-68 SWB, if the attached drawing is correct for the Black/Blue wire that supplies power to the dash lights? The connector from the main harness will be in the trunk area probably above and slightly to the left of the fuse panel. I am trying to make one and am want it to be as close to factory original as possible. My examples are cut and all mangled.
    I'd really appreciate it. Thanks.
    Steve
