Thread: Dash labels - HAZARD
    Jun 2012
    London, Ontario, Canada
    I’m redoing the dash vinyl after completing the wiring on my ‘73S.
    The vinyl on the left of the steering wheel looked to be original but it only had the LIGHTS label and corresponding mounting holes. There are 2 mounting holes over the hazard switch in the aluminium fascia, but there were none in the vinyl.
    Is that normal?
    Ravi
    PS. Sorry the pic is inverted, but I can’t seem to change that.
    Early 911S Registry # 2395
    Oct 2010
    Southern Ca.
    Normal , and where did the lights label come from ?
    Jun 2012
    Was on the car when I bought it and mounts with two press fit studs on the back into the aluminium back plate through 2 holes in the vinyl. Definitely stock. I read somewhere that the labels started in ‘73.
    Oct 2010
    Southern Ca.
    Good to know about the label , thanks . My car is an early '73 with no label .
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    My 8/72 MY73 has a light, but not a hazard label.
