Thread: No start
    Senior Member DavidRS's Avatar
    Oct 2011
    where ever I am
    No start
    Posted this on pelican. Thought I’d put it up here too. 912 chassis 86 3.2 motor
    Have electrical issue. Left Scottsdale Tuesday and got to Parker. Turned off car then turned off lights. Filled with gas, made a call. No start. No lights, no dash nothing. Suggestion was ground. Removed from chassis (using bolt that holds battery to body) cleaned and replaced. Started and has run great ever since tonight
    Drive 10 miles with lights. Thru stop lights, signs, etc. upshift and down. No issue. Turned a corner total electric failure. Did the ground strap dance but no joy. Note there is power in the battery and interestingly the overhead door light works. No dash, no headlights no start
    Thoughts?
    My Inspiration
    '86 44 Turbo, black/red,7's and 8's fuchs, autothority - sold (rocketship)
    '97 Boxster, first delivered in DC Metro, silver/red -sold (huge mistake to buy this one)
    '99 C2, silver/black, RoW M030, limited lip, short shift - sold (good ride, but...)
    '69 912, 3.2 with all the trimmings
    (finally got air cooled)
    Early 911S Registry Member 2044
    Oct 2010
    Southern Ca.
    How's the connection for the smaller wire on the + battery terminal ? How's the DME relay wired?
    Oct 2011
    where ever I am
    quick update, if anyone is interested. Fried the buss on the back of the fuse box. (1969 912 has two separate 8 fuse boxes). Shop did a temp fix, but I opted to install the Refuze boxes for extra added peace of mind
    My Inspiration
    Senior Member csbush's Avatar
    Jan 2009
    San Antonio Texas
    Thanks for sharing your experience and the fix. Always interesting to hear how problems are resolved
    Chuck
    Early 911S registry #380
    '70S
    '75S
    '96 C4S
    '65 R69S
