Results 1 to 9 of 9
Thread: 4.5 x 15 Fuch valve stem help needed?
    Aug 2019
    I am trying to find valve stems to fit my 4.5" Fuch and can't find an up to date answer anywhere.
    The standard snap in TR415s won't fit properly / won't reliably stay in. I'm aware there was an older source for these a few years ago which worked better but can't find any now.
    I found some screw-in metal valve stems in the wider 15mm / TR415 size but they aren't long enough for the thickness of the hole in the rim, and also the nut won't hold it properly at the 45 degree angle it needs to seal the valve to the rear face of the rim.
    1. does anyone have a source for (ideally good looking) valve stems which are both wide enough and long enough?
    2. how have people dealt with the 45 degree angle of the stem protruding to the front face? - it's not a problem with snap in valves but with the screw in type having such an angle stops you screwing the retaining nut down properly.
    3. is there a completely different option I haven't thought about? (I can't run tubes in my tyre size by the way).
    Any help much appreciated I've been scratching my head for weeks over this one.
    This thread might help:
    http://www.early911sregistry.org/for...4-5-quot-Fuchs
    Good luck,
    cm
    Aug 2019
    Good luck,
    cm
    Thank you, I’ve read that and it was useful in getting me this far. Unfortunately it’s from 2010 and the valve stems they talk about aren’t made any more and I can’t find any old stock.
    The bbs screw in type he mentions aren’t an obvious result when searching so without a part number and a photo of how they dealt with the angle it’s back to the search...
    Call Harvey......he has a fix and a source for stems that work.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Aug 2019
    Quote Originally Posted by smedley View Post
    Thank you, who is Harvey?
    Harvey Weidman:
    Weidman's Wheels
    1675 Wyandotte Ave
    Oroville, CA 95966
    Phone number (530) 534-7903
    Our wheels being done from all over the world...
    Aug 2019
    Lovely, thanks
    Tubes dont have correct valve stems? Tires originally ran with inner tubes
    Aug 2019
    Quote Originally Posted by CarmelSkip View Post
    Tubes won’t work in my tyre size sadly - I have low profile tyres as it’s a lowered vehicle and tubes just tear themselves up with the low sidewalls.
