Results 1 to 10 of 12
Thread: Advice on clutch for 71 with a 2.7?
    Nov 2016
    SoCal
    Hey all - I'm building a motor for my car. Right now it has a 2.7, basic setup with carbs. Trans is a 911/01. Trans has been rebuilt and has a billet center bearing carrier. I don't launch 1st car. It will get an LSD + reinforced side cover too.
    So I'm curious on clutch. if I understand, these use a 225mm clutch different than the 901. What I want is a clutch that could take an RS spec+ power, but not be heavy, or 'hair trigger'.
    Looking at options to clutch, PP, flywheel, etc.
    IMO don't use a Sachs sport pressure plate . The '70 , '71 push style release fork and cable are not up for the sport PP .
    Nov 2016
    SoCal
    Yeah this is the sort of info i'm curious on, if stock is "OK" or what can I do to ensure I have adequate gripping. The clutch in there now I ease into it, it doesn't slip under load. It did when i first got it and needed adjustment. Which its nearly out of.
    Nov 2016
    SoCal
    Anyone else?
    The stock 71 clutch is more than capable of handling the power from a 2.7.
    Nov 2016
    SoCal
    Sufficient for ~250hp(knock on wood)? This will be a pretty hot 2.8 build.
    What about the transaxle itself ? 250 HP may be too much . A stock '77 2.7 has 160 DIN HP .
    Quote Originally Posted by Spyerx View Post
    Yes. It's certainly no weaker than a 2.7 clutch.
    Nov 2016
    SoCal
    Well i don’t plan to clutch drop first. Trans is fresh and has billed middle bearing carrier. Will be adding an lsd and billed side plate.
    Ok so suggestion is keep it stockish. I may go with a lighter pp and flywheel setup.
    I don’t want over aggressive clamping force trashing the 71 style fork system but don’t want it slipping either...
    Nov 2016
    SoCal
    Well i don’t plan to clutch drop first. Trans is fresh and has billet middle bearing carrier. Will be adding an lsd and billed side plate.
