Thread: 915 CONVERSION: 1984 hub + stub axle on steel trailing arms?
    Feb 2012
    Sweden
    Hi
    Is there a way to make the 1984 100mm / 6x8mm stub axle and hub work on the steel trailing arms? Or should I combine the 1970 hub with the later 1984 stub axle in order to make it work?
    (I have a 915 with the 100mm CV joints / drive shafts that I want to install in my 1970 car with steel trailing arms)
    Thanks!
    Johan
    -70 911E
    -84 3,2 Sold
    Oct 2010
    Southern Ca.
    I think the axles will be interchangeable . I once put '73 stub axles in a '79 911SC .
    Feb 2012
    Sweden
    Thanks Richy, I suspected combining the older hub with the newer stub axle would work
    Out of curiosity, has anyone tried this solution proposed by Patrick Motorsports;
    https://patrickmotorsports.com/produ...33feb2d4&_ss=r
    -70 911E
    -84 3,2 Sold
