Results 1 to 2 of 2
Thread: 1967 S engine
    Nov 2018
    Malta
    1967 S engine
    Good evening friends,
    After giving the engine a good clean , I spotted a loose bolt which is inexplicable to me not being a mechanic.
    I thought I'd show you a picture of it to see if this is normal or not . And of course if not normal, if it should be tightened asap.
    Thank you
    Name:  DSC_0119 (2)_LI.jpg
    PORSCHE 911S '66
    Just looks like a bolt clamping two pieces of sheet metal together,,,,should take a 10mm wrench if so.
Message Board Disclaimer
