Results 1 to 9 of 9
Thread: Front Slam Panel - Water Bottle Hole
    Hi, has Anybody got a definitive VIN or cut off date of when the water bottle hole was introduced I assume mid 1967?
    Senior Member moito's Avatar
    AUSTRIA (tu felix)
    i`v some interesting pix for you....it`s a very late MY67 that already got the panel with the hole punched but it got closed with a round patch.
    note also the mounting bracket is present ...nope the panel was not replaced..all factory
    Very interesting !!
    Vin is 306340 mid MY 67
    I suppose it’s NLA from Porsche
    Restoration design? Don’t suppose you have a photo
    Ray
    I am sooooo annoyed with myself !!!
    I thought I had researched the slam panel well but obviously not !!!
    I have installed the incorrect version sourced a excellent water Bottle, pump, brackets Lines etc I can’t see how I made such a big mistake!!
    Do you know if the washer bags and accessories are available? Does it have a pump etc I have no idea
    3065XX has no water bottle hole.
    I have the new Latch panel - no hole but with the plastic bottle attachment on the inside
    Please tell me that is correct ?
    Aug 2017
    el sobrante ca.
    Dec. 3. 1967 #11860131 model 1968 L built in 1967 … hole
