Results 1 to 5 of 5
Thread: Behr oil cooler for '68t engine
    Pacific Oil Cooler Service has advised me to trash this and get a new one.
    Anyone have one of these laying around?
    Thanks,
    Dan W.
    I might have one for you. I need to test it to make sure that it does not leak.
    Erik Johnson - (303) 443-1343 ext. 2
    You are aware that those are available new,,,right?
    May 2006
    CT
    I have one. Pressure tested...No leaks.
    PM me if you are still looking
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Tom,
    Thank You. I have found one. I will keep you in mind if there is any problems with the pressure testing.
    Dan
