Results 1 to 10 of 12
Thread: Mechanical Fuel Injection Help in New England
    Looking for recommendations for experienced Mechanical Injection service in New Hampshire , Vermont, Massachusetts, Maine or anywhere else close by.
    Dennis
    Rick Cabell on this forum. Near Burlington, VT.
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    1132 honda snowblower
    member Jackson Hole Ski Club
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    Also consider Automobile Associates in Canton, CT (west of Hartford). The last time I visited them (in July) their shop was heavily populated with MFI cars.
    Alan
    N.J.
    Alan
    New Jersey
    1969 911S
    1964 E-Type roadster
    1987 M6 coupe
    1988 328GTB
    What issues are you trying to resolve?
    My main problem is a hesitation at very low throttle, like not enough fuel? Runs great when you open it up. This is a 1970 911E ,
    The car was taken out of storage about 4 years ago. Prior to that is was an in-op for quite a while. New gas tank, fuel pump, throttle bodies cleaned and freed up . and all the typical other problems of a car that sat. It has been run for about 4,000 miles over the past 4 years. I have run probably 4 or 5 Techron treatments through it. It has had the same problem the whole time no better / no worse.
    Have you checked your distributor advance mechanism.
    Try a few tank fills with stabil.
    A thousand miles a year is not much to keep everything loose in the injection pump.
Message Board Disclaimer
