Thread: Eng popping when decelerating / exhaust leak repair
    Jul 2014
    SF Bay Area
    Car is a 70T w/Zeniths
    I am getting some popping when decelerating that is getting Louder as of late and thinking the exhaust leak that I have behind the lower point of this bracket (see pic) is the issue. The bracket is no longer connected at this point. I hope this is the only leak but will be checking for others this wknd.
    Also aware that this may be a carb issue (comments welcome).
    What is the best product/procedure to repair a hole like this?
    Try JB Weld.It should hold long enough to rule out or confirm the cause.
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    1132 honda snowblower
    member Jackson Hole Ski Club
    Jul 2014
    SF Bay Area
    Will try extreme heat JB thanks
    Dec 2009
    Copenhagen, Denmark
    Is it time for SSIs?
    James Hurst #1638
    R Gruppe #514
    Jul 2014
    SF Bay Area
    Will definitely getting SSIs when its time to replace them. The hole behind that strap was about 3/4 inch long, the JB weld made a big difference.. I have been out for 2 test drives, a few small pops the first time, none on the second run and I made an effort to recreate backfire conditions - decelerating/down hill, esp when pushing it a bit. Not sure how long it will hold.. short of replacing, I assume it would be way better to get a weld repair.
