Page 16 of 44 FirstFirst ... 6141516171826 ... LastLast
Results 151 to 160 of 435
Thread: 300090
  1. #151
    Senior Member pss's Avatar
    May 2014
    Netherlands
    see early in this thread.
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
  2. #152
    Quote Originally Posted by pss View Post
    That information / conclusion drawn is not correct / complete. Cars could be ordered w/o radio but w/ antennae. So no blaupunkt remark, but an antennae could be factory installed on drivers side.
    Richard
    Richard
  3. #153
    Quote Originally Posted by preS View Post
    Richard
    Richard
    Yes, this is in line with 356 practices where many cars were ordered with an antenna but without a radio
  4. #154
    Senior Member 300090's Avatar
    Sep 2019
    FRANCE
    Kardex /Antenna option
    Richard
    Quote Originally Posted by 718RSK View Post
    Thank you all,
    The Kardex (for 911) indicates ordered options like radio or webasto.
    Does the kardex indicates an antenna option when no radio was ordered?
    Philippe
  5. #155
    May 2014
    Netherlands
    The steering rack of the 300700 shows Feb 1965 assembly and a cast of 20/64 (though the 4 is a bit obscured). Next to the casting date there is a 'K' in a circle and a bigger font '2'. Not sure what that would be.Name:  IMG_20200103_155003517.jpg
Size:  97.2 KBName:  IMG_20200103_155048385.jpg
Size:  91.7 KBName:  IMG_20200103_155017468.jpg
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
  6. #156
    Quote Originally Posted by 300090 View Post
    Thank you all,
    Philippe
    Yes.
    Richard
  7. #157
    Sep 2006
    La Quinta
    my records show that until car 1115 all cars had the polymer dripping pans. I think they experienced problems with this while water was leaking from the seam between the 2 halves. Then they switched to the fiberglass.
    Great to see that the very early ones had a different design apparently.
    #301111 has the polymer type with a number on it.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
  8. #158
    Hopefully not diverting too far from the tread's intent, but pictures clearly show a steering damper. A look at the Pet seems to indicate use through '68 models. I think I have read that the some owners indicate no damper in '67 especially as to 911S. Anybody have the definitive answer on this? Then back to this very interesting thread. Really enjoying.
  9. #159
    Mar 2012
    Scotland
    For what it is worth, some comparison to early 1965. The 1964 versions have only 1 mount for the damper (blue circle), as I also see in early 1965. See picture of 300700. However my 700 version has a small console for the number, which I do not see on the 1964 versions. Will check the cast tomorrow. Later cars had a second mount where my console is (red circle).
    Attachment 511276
    Later cars have 2 mounts and I assumed this would be to use the rack for both LH and RH steered cars (?) Discussion was not concluded I think and I have little evidence on when this changed. At least before 1379, as this car has 2 mounts.
    I posted this feature in the 'special 64 features on 65 cars' thread, post 316.
    How do you explain how my car has a steering box casting date 52/64, has two damper mounts, and assembled 7/65 and fitted to a RHD car despatched 17 Sept 65.
    Boom boom, there are always anomalies!!
    Ian
    Member 3440
    1965 RHD 302136
  10. #160
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by DEEMAN View Post
    Ian
    Member 3440
    1965 RHD 302136
    http://www.early911sregistry.org/for...=1#post1037951
