Thread: Starter cable grommet help
    Mar 2018
    TN USA
    Folks,
    Does anyone have a source for the grommet that goes on the end of the tunnel under the car where the starter cable exits the tunnel? Please see attached pics.
    In the PET is see 2 part numbers. 999 702 051 50 seems to be for the grommet upfront by the gas tank and then for part # 901 611 923 00 I can't find anything.
    Any help would be appreciated!
    Steve
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Have you tried McMaster Carr?
    https://www.mcmaster.com/grommets
    1969 S Coupe #761
    Early S Registry #1624
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    don`t have the part# handy but the grommet should be available from porsche(have several in a not to old porsche bag)...did you check under the dirt for a part#
    Mar 2018
    TN USA
    don`t have the part# handy but the grommet should be available from Porsche(have several in a not to old Porsche bag)...did you check under the dirt for a part#
    I'll check with Porsche on Monday. If you had a part number that would be great. Mine's in pretty bad shape and I don't see a number on it.
    PET '65-69 911 Fig. 9-02-10, #3 911.611.921.00 Rubber boot Qty: 1 PCNA List 2019: $9.99
    Stoddard, Pelican, Sierra Madre
    Mar 2018
    TN USA
    Quote Originally Posted by JimmyT View Post
    Thank you!!!
