Results 1 to 10 of 15
Thread: Where does this spring go?
    Dec 2013
    Connecticut/Florida
    I am assembling the oil lines for my 1971S, the ones in the engine bay that houses the filter/thermostat etc. Everything appears good - except I have this one spring leftover and my disassembly photos don't show it. Its different than an engine oil drain spring - any ideas where this should go? Thanks as always in advance....
    Name:  Screen Shot 2019-09-21 at 4.18.31 PM.jpg
    1971 911S Coupe - Gemini Blue
    Might help if you laid a quarter next to it for dimensional help
    Dec 2013
    Connecticut/Florida
    Now with a quarter for size
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    I’ve never seen one of those before, but sometimes people put springs inside of oil lines to prevent them from kinking. Maybe it was inside that lower oil hose to the left of the thermostat?
    Alan
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
    Aug 2016
    NE Ohio
    subscribed
    Is that first picture yours or canford's ? Is that filter housing bolted to the oil tank? Angles look wrong.
    Dec 2013
    Connecticut/Florida
    Not mine Ed, just a photo off the internet for info.
    I saw Canfords name on the photo, so didn't think it was your car, but agreed with Alan that springs are sometimes installed in hoses, usually radiator, but had never seen one used in oil lines. The installation in the picture looked like the set was slightly the wrong angle and therefore put a little more bend in that lower hose, but I found a picture of mine which seems to be of the same overall angle, so that isn't the problem,,,,,and I don't know where the spring would've been used
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    check your oil console housing
    Dec 2013
    Connecticut/Florida
    Quote Originally Posted by dirk07 View Post
    Thanks- yes, that spring I have, and its heavier duty than the one shown above.
