Results 1 to 9 of 9
Thread: Another Heinzmann extinguisher replica unit
    Thanks to great info and photos found here on Early S I am nearly done making a replica Heinzmann extinguisher that is slighlty smaller but roughly proportionate to the real unit. I used mostly hand tools (files) to make the valve. I use two old refillable solvent containers to make the tank.
    I still have to make the top shroud an am currently waiting on aluminium for that.
    Here are a few photos of the process. I used a thick tow hook as the base to carve out the valve.
    IMG_6475.jpgIMG_6496.jpgIMG_6498.jpgIMG_6502.jpgIMG_6503.jpgIMG_6507.jpgIMG_6508.jpgIMG_6512.jpgIMG_6525.jpg
    May 2011
    Chelsea, Québec
    Wow! That looks really well done!
    1966 911 Coupe - Slate Grey - 304598
    Member # 1616
    Senior Member patrick911's Avatar
    Mar 2007
    Melbourne, AUS
    Kudos,
    I remember you asking for one a while ago, so respect for taking the action to build one yourself!
    I've got one already for my RSR rep, but just out of interest: Are you planning on making a series and selling, or was this pure for your own car?
    Member #3058
    1973 911 2.4T
    1976 911S -> 2.8RSR rep
    Thank you for the compliments.
    I enjoyed learning about these units and making this one but due to the amount of time required to make it I am not making any to sell.
    I would be interested in your decal set,regards paul
    Feb 2005
    Montreal, Canada
    Nice !!
    Are you planning to reproduce the "diamond" aluminum plate cover to go over it ?
    JD
    1970S Coupe, Blood orange #1436
    1965 Coupe, Dolphin gray #1506
    R Gruppe #647 ; S Registry #1666
    Hi JD,
    I have not seen your cars around (I am in Montreal as well). Cool to know there is a 65 around!
    I am working on the cover at the moment. Ideally I would find a place to have the pattern machined out of a thick alloy sheet (that I have sourced already) and then bend to shape.
Message Board Disclaimer
