Thread: steering damper
    steering damper
    Early steering racks had a steering damper, and later ones did not. What's your experience, are they worth using if your rack has the mounts?
    Lightbulb
    This thread might help for reference:
    http://www.early911sregistry.org/for...rly-911-or-912
    Hope it helps,
    cm
    Senior Member 9er's Avatar
    Apr 2010
    Adelaide Australia
    As best I can work out, if you upgrade your early rod ends to 930 type the damper can no longer bolt up.
    Feb 2011
    Northern VA
    I believe Elephant Racing sells a 930 style end that bolts up to/matches a SWB higher ratio rack.
    I have a 356 damper on the shelf and wonder if simply modifying one end would make it work. Any thoughts?
    If the dampers were worth using then Porsche would have kept using them...
    -Marco
    TLG Auto: Website
