Results 1 to 10 of 13
Thread: Matter roll bar padding
    Looking for about 3-4 feet of Matter roll bar padding. They are no longer around so it’s hard to find.
    I have ordered a couple samples of generic from a couple of the big national hot rod supply houses without any luck. Black of course.
    If anyone can help please email direct to: rcabell911@gmail.com
    rick, look at this, maybe helps you:
    http://www.matter-motorsport.fr
    regards
    uwe
    Jan 2011
    Sunny Southern France
    Matter is still active, at least, there's a company over here doing rollbars:
    http://www.matter-motorsport.fr/societe/
    What's your diameter please? I can give a call.
    Olivier
    Edit: simultaneous post !!
    Thanks so much guys. diameter is 40mm.
    Jan 2011
    Will give a call.
    Maybe they still have some, but i doubt. Looks like FIA asks for something different now.
    You may use this
    https://www.merlinmotorsport.co.uk/p...tre-length-rcp
    With stencils paint?
    Will post results tomorrow
    Thanks Oliver. I don't care about the printing "Matter". Plain back is fine. This is 70's vintage padding I am trying to match.
    Oliver, The padding from Merlin looks pretty good. If Matter is a no go, I'll contact Merlin.
    otherwise, this could possibly be an alternative for you
    http://www.longacrer...t---Black-Taped
    regards
    uwe
    I ordered the "high density" padding from them and it was not spongy foam, it was a hard plastic like material. If Oliver has no luck, I will order the medium density from Longacrer.
    Jan 2011
    Hi,
    I called Matter, they don't have anything. Sorry.
    Maybe stupid, but, you could try some construction shop. They use something similar for tubing insulation...
    Olivier.
