Thread: Recaro Comfort Seat Frame Repair
    The upper part of this 1972 Recaro Comfort seat was very loose and not mated properly to the upper part of the seat recliner. I thought I just needed to tighten the mounting bolts but unfortunately that was not the case. I noticed the four 6mm nuts (two on each side of the seat) that are welded to the inside of the seat frame had either broken off or were completely stripped. I decided to see what I could do to get this fixed.
    The first step was to bring the seat top to an upholsterer to remove the seat cover in such a way that it can be reused after the frame repair.
    Here is the upper seat frame with seat cover and padding removed. You can see a burlap sleeve and a series of elastic donuts and bands mounted to the sleeve and seat frame which gives the seatback that springy feel. There is a piece of wood on the bottom of the frame which is where the bottom of the seat cover is stapled to.
    Here is frame with burlap, elastic and wood removed. You can see the tubes for the headrests on top.
    Here's part of the damage. A missing nut (small hole) with a very large hole drilled into the frame where somebody attached a clip-on nut
    Here you can see frame after it was blasted followed by a shot of the stripped nuts that will later be ground down.
    After grinding down the damaged nuts you can see the new nuts welded to seat frame (inside frame) followed by a shot of the seat hinge mating area (outside frame). Notice large hole that was drilled into frame for the clip-on nut has been repaired. Before sending back to the upholsterer I will apply some primer to the frame.
    Jun 2012
    London, Ontario, Canada
    For some reason those frames seem to rust a lot. I went through the same process here. http://www.early911sregistry.org/for...ation-question with welding in new nuts etc. I powder coated the seat frames so they would last for all eternity.
    Ravi
    Early 911S Registry # 2395
