Results 1 to 9 of 9
Thread: Help identifying air cleaner bases
    Feb 2011
    Minneapolis, Minnesota
    Hello All,
    I have these bases I had powder coated. However, they did not work on my 1970 with mfi. What are they? It looks like they are two right side bases. I want to sell them but I need to be sure what they are before I do that. I appreciate the help. Regards, Steve
    Steve ESR#1934
    Member AKAMick's Avatar
    Sep 2018
    77°50′47″S 166°40′06″E
    Look like Zenith carb air cleaner bases.Name:  Photo Aug 10 4 13 02 PM_zpsi0cy8ewh.jpg
    Current fleet, mostly rubbish automobiles and other assorted junk.
    May 2006
    CT
    I believe those are the early SWB Weber type.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Same part number x 2. They aren't "handed". 901 108 220 00
    Early S Registry #235
    rgruppe #111
    May 2014
    South East USA
    they seem identical in every way to my early 1971 T bases, that must have started with zeniths, but are now PMO.
    Make note of Tom's reply , they are SWB early Webers .
    @AKAMick
    These "full radius trumpets" work very well. Thanks to Paul Abbott (Performance Oriented) and test pilot Ed Mayo.
    rgruppe #111
    Feb 2011
    Thank you to all that contributed. Regards, Steve
    Steve ESR#1934
    Senior Member BURN-BROS's Avatar
    Sep 2003
    Camarillo, Ca.
    Hi Steve, As far as the Porsche catalog is concerned, There is only 1 filter base for 1966-1970. That is part #901-108-220-00. In 1971, Porsche made the air cleaner housing out of plastic for all of the models. That air filter base # 911-108-014-00. The clip mounts are in different locations to account for the different clip they used.(They used the same clip as the 1972-73 air cleaner).
    Aaron Burnham
    Burnham Performance
    1071 Avenida Acaso ste D.
    Camarillo, Ca. 93012
    805-240-6931
    _________________________
