Results 1 to 10 of 10
Thread: FS: VW288, VW261, P201/Matra 313, P7
    Mar 2004
    Castro Valley, Ca.
    *** only the P7 remains ***
    add shipping.
    VW 288 transaxle backlash measuring tool as pictured in original box. $300 SOLD
    1940 Mercury town sedan
    Mar 2004
    Castro Valley, Ca.
    add shipping.
    VW 261 clinometer for measuring and setting swing arms, spring plates, ride height and various other operations. $300 *** SOLD ***
    Mar 2004
    Castro Valley, Ca.
    add shipping.
    well used set that has already outlived 2 generations of users and will outlive many more.
    $400 as a set only SOLD
    Mar 2004
    Castro Valley, Ca.
    P7 late version. please note the aluminum combustion chamber guides. earlier version per Jon B. description below. brass ID plate. $500
    Quote Originally Posted by typ901 View Post
    P7 believed to be a first generation version. please note the aluminum combustion chamber guides. later versions used wood guides. brass ID plate.
    Jerry, your P7 is the later 356 & 912 version. The early versions had hardwood bases and chamber domes.
    The laminated wood bases and alloy domes like yours were stronger and lasted longer.
    Jon B.
    Vista, CA
    Nov 2011
    Bluffton, SC
    Ill take the VW 261
    Not sure I will ever use it - Its just too cool to pass up!
    Please PM total and preferred payment method
    (Snail mail to 29910)
    Regards,
    Charles
    Mar 2004
    Castro Valley, Ca.
    @Jon B.
    thank you sir. I figured that if anyone would provide needed clarification re: Special tools it would be you. description edited.
    @Charles
    I thought the very same thing when I bought it, although I did actually use it... once to be exact PM on the way.
    Mar 2004
    Castro Valley, Ca.
    time for a bump.
    Mar 2004
    Castro Valley, Ca.
    P201 / Matra 313 set is sold
    Mar 2004
    Castro Valley, Ca.
    only the P7 remains
