Thread: WTB: Recaro Seat Slider Pin
    Senior Member uptheorg's Avatar
    Apr 2012
    Scarsdale, New York
    I have a seat base that uses special "trick" pins to hold the Recaro sliders in place. The pins go through the one of the 3-4 holes that are in the typical Recaro slider leg. I only have 3 pins like this and would like to get a fourth. (There is NO threading where the pin enters the base.)
    Photo #1:
    Pin separated from frame - note the small ball bearing at the end: this is on a spring so it can compress inside the frame and then pop out and sit in a hole a couple of inches in
    Photo #2
    Pin "partially" installed through slider into the base (frame). It needs to be pushed in about a half-inch and lined up to be seated properly.
    Photo #3
    My finger points to the ‘hole’ in frame where the end of the pin seats
    Has anybody seen something like this and, better yet, does anybody have one I can get?
    Jim
    Jim
    __________________________________________________ ___________
    Early S Registry #2359
    1970 Porsche 911 Rally 2.4
    2018 Porsche Macan GTS
    We use these to hold the body in place on a vintage sports racer that I work on. I believe that Pegasus racing parts sell them in assorted sizes
    Thanks, Rick
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    in german these are called Kugelsperrbolzen.
    However I've never seen them to replace an M8x16 Bolt
    I believe that these pins are a variation of MS17990E, Pin, Quick Release, Positive Locking, Double Acting, Ring Handle.
    The attaching ring is just a stamped steel ring squeezed into a groove on the head. It can be easily removed.
    If you are bothered by the wire ring handle not matching, you could buy 4 instead of 1.
    After you measure the diameter A and the grip length, you can probably find some surplus items available on eBay.
    Good luck, Jimmy
    Apr 2012
    Scarsdale, New York
    Wow! Great feedback from all -- thank you so much.
    Jim
    Jim
    Apr 2012
    Scarsdale, New York
    Turns out these pins are not hard to find -- available in many sizes and diameters on Amazon. I found the one I was looking for:
    Thanks to all --
    Last edited by uptheorg; 11-07-2019 at 10:15 AM. Reason: corrected QR pin picture so it matches the one I needed
    Jim
