Results 1 to 7 of 7
Thread: Cloth horn button and loose steering wheel for momo or abarth
    Jul 2017
    Glendora california
    Hello. Everyone
    I just installed an abarth wheel with mono hub. Now I have a little play in the wheel . My car is a 1972 and all of the threads I found reference 74 + cars, can anyone give some guidance. I did notice that we forgot to reinstall the spring and I will put that in
    Also. I would like to cover my horn button with the seat fabric and have searched to see if anyone has done that ? Any ideas?
    Thanks for all the contributions to this forum it has really made this build enjoyable
    Aug 2011
    Eugene, OR
    Todd, I think the spring is necessary to locate it properly. Try that first.
    - Arne
    And,,,,spring cup.
    Aug 2009
    SF Bay Area
    Make sure these 2 pieces are installed correctly. Problem solved. I used a Nardi hub for the pictures but your Momo hub is no different in regards to the spring and bushing.
    Jim
    Changing horn button Leather/vinyl
    Some years ago I made a simple press to form the needed support horn button dome - to which the vinyl/leather can be attached.
    Pressed a couple button domes from Aluminum and glued the leather to it.
    The combined thickness of the leather and the dome needs to be equal to the Mfg plastic piece. Note the notch at the 5 o'clock position.
    Good luck with the vinyl of your choice.
    Bob
    Early S Reg #370
    Todd, for the horn button I might be able to help you out. I've done several customs horn button jobs though in leather usually. If you can message me through Instagram that would be easiest. Username there is _more_momo.
    If you dont have Instagram, you can PM me here. Please include a pic of the fabric. I do assume you need that piece as the center of a momo horn, right?
    Click to see my momo collection --> For those interested in my steering wheel collection, feel free to have a look
    Quote Originally Posted by Toddlaunchbaugh View Post
    Happened to stumble upon this thread again, thought i'd share the outcome.
