Results 1 to 10 of 10
Thread: Closing mechanism 1967 Targa
    Senior Member softwindow's Avatar
    Jan 2015
    Bonn, Germany
    Hallo experts,
    which closing mechanism is correct for a 67 Targa?
    Kind regards
    AnkeName:  Porscheschloß1.jpg
Size:  43.2 KBName:  Porscheschloss4.jpg
Size:  35.1 KBName:  porscheschloss2.jpg
Size:  50.5 KBName:  porscheschloss3.jpg
    356 A 58 silver
    302485 light ivory
    500248 Softwindow light ivory
    500441 Softwindow S light ivory
    2.2 S Targa geminiblue
    2.4 T Targa black
    2.4 S Targa vipergreen
    2.7 RSR tribute green (original 2.4 E 1972)
    Macan GTS black
    Boxter S black
    997 Turbo Cabriolet black
    BMW R 17
    BMW R 69S black with Steib 500
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    both are correct for 67.. just depending if a early to mid modelyear car or a later VIN... parts catalog gives the exact changeover VIN(for coupe 308something if i remember correctly) pix 1+3 are the later version.
    br
    me
    As Franz (Moito) wrote, check the change over vin number, but I suspect the 2 + 4 combination if at all on a 67 must have been for very, very early builds. I have never seen anything on a 67 other than 1 + 3, whether on a 912 or 911, Karmann or Porsche build.
    Jan 2015
    Bonn, Germany
    Thank you Franz,
    thank you Jim,
    does someone have the part catalog and knows if 500248 and 500441 were built after the change over vin number?
    Kind regards
    Bernd
    356 A 58 silver
    302485 light ivory
    2.4 T Targa black
    Macan GTS black
    Boxter S black
    BMW R 17
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Jim Morris View Post
    the reason why porsche changed the door striker/lock was because under certain driving conditions the doors could pop open.very often cars have been updated. e.g.when in the workshop for service (would not wonder if even without telling the owner)...the process of updating is described in the workshop manual ...
    May 2013
    AUSTRIA (tu felix)
    just had a look at the online katalog and i`m a bit confused now....need to compare with my paper katalog...mybe i`m wrong with the VIN changeover....will report back
    Senior Member jim amato's Avatar
    Feb 2011
    n.e. ohio
    I have 3 -67 targas they all have the later style latch - vins 550343, 550516 and 500712
    registry #2072
    Jan 2015
    Bonn, Germany
    Thank you Jim.
    356 A 58 silver
    302485 light ivory
    2.4 T Targa black
    Macan GTS black
    Boxter S black
    BMW R 17
    The parts book indicates the earlier system (2+4) used on coupe through 305100. The first 67 Targa (500001) was built with coupe series starting at 307351. This is for "normal." Same essential sequence pairings holds for "S." Thus, it is virtually certain that all coupes (and surely targas) of 1967 vintage had the later system (1+3) above. Moreover, as Franz points out above, the parts book calls for replacing the earlier system with the later system whenever repair is needed. Additionally, it can be concluded that the earlier system ended at the end of 1966 production, as the last "official" 1966 unit was indeed coupe number 305100.
    Jan 2015
    Bonn, Germany
    Thank you Jim and Franz.
    So we will use the newer model.
    356 A 58 silver
    302485 light ivory
    2.4 T Targa black
    Macan GTS black
    Boxter S black
    BMW R 17
