Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: Air Cooled radials. . 1943
    The Greatest Generation...
    I have quite a few hours behind a r985 supercharged radial. 450hp.
    Wright Cyclone
    The US military's other radial of WWII, the Wright Cyclone engine series.
    Jon B.
    Vista, CA
    Nov 2009
    Cecil pa
    Nice stuff..wow.
    Those with flying experience may understand the following (P-47) better than rest of us :
    Under 5000ft, you're a meat shield
    Under 10,000ft, you're at the mercy of any German plane
    At 15,000ft, the turbosupercharger kicks in
    At 20,000ft, you become competitive
    At 27,000ft, all engine types performed their best. You are now pretty OP vs. anything German at this height
    At 30,000ft, where bombers flew, you fly faster and out-turn German planes
    Your ceiling is 43,000 ft!!!! Nothing the Germans had, even the Fw-190D - was a match for you flying this high
    - Climb first. The P-47's most abusive ability was high-alt performance. Etch 15k ft and 20k ft into your mind, because that's when the engine starts showing.
    - The plane is heavy and gigantic. Use flaps to help turnfight - but this is a last resort.
    - Instead, the -47 is excellent at rolling. Fake your turn direction through roll.
    - If you're carrying fuel tanks, use main tank fuel to climb until 50%, as below this is the -47's best flight performance, then toggle your drop tanks for fuel.
    - The -47D model is the first 'bubbletop canopy'. D-20 model introduces the R-2800*. D-22 model adds the paddle prop*. You're now OP at 30,000.
    - A good defense to enemy boom & zoom is the 'TopGun'. Turn to a side, then apply flaps and roll underneath to get a crack shot on your adversary as they pass.
    - You can take damage if necessary. The engine is a piston aspirated monster. Losing pistons is survivable.
    Jul 2014
    Air Cooled Radials
    Pratt & Whitney R-4360 Wasp Major
    4-row, 28 cyl = 4360 cid (hence, etc) . . . .
    . . . + twin turbos + supercharger = 4500 hp
    Jets saved the Mechs from dealing with these
    I believe there were 3 turbos (back then called Power Recovery Turbines) spaced 120 degrees apart. They did not compress the air back to the intake like a car turbo, but extracted the exhaust energy and they connected directly to crankshaft drive via bevel gears. If I remember correctly from my old power plant instructor, they managed to recover almost half of it's rated HP thru the PRT's.
    Mine was a “junior wasp.” Still plenty of torque roll!
    Great aircooled!!!
    Instagram
    Twitter
    Air Cooled Radials, 1943
    We should include the Wright R-975 Whirlwind 9-cylinder radial in this thread.
    The Continental-built version powered many M3 Lee and M4 Sherman tanks during the war.
    Jon B.
    Vista, CA
    Quote Originally Posted by 3Litre View Post
    . . . I believe there were 3 turbos (back then called Power Recovery Turbines) spaced 120 degrees apart. They did not compress the air back to the intake like a car turbo, but extracted the exhaust energy and they connected directly to crankshaft drive via bevel gears . . .
    Think you're referring to the Wright R-3350 'Duplex Cyclone' --- 18-cyl, twin row radial, up to 3700 hp . . . used to power the B-29 + completely different engine
    http://www.autospeed.com/cms/article...Major&A=113208
    Thunderbolt
    Quote Originally Posted by 62S-R-S View Post
    Hm
    Republic P-47 Thunderbolt --- aka 'the Jug'
    Huge plane --- empty weight = ~10k lbs . . . vs Mustang = ~7.5k lbs
    Dunno about its high-altitude performance. It's biggest attractions were . . .
    1) phenomenal fire-power --- 8x .50 machine guns = 100 rounds/sec would literally vaporize any target
    2) excellent range --- 1st Allied fighter capable of escorting bombers all the way to Berlin; P-47N had a ~2k mi range and was specifically designed for escorting B-29s over the Pacific
    Mustang was a better performer, though --- especially in air-to-air . . . so the 47s were put to use as ground attack aircraft --- in addition to their punishing armament, they could carry all kinds of bombs + rockets, and survive damage that liquid-cooled aircraft couldn't. Especially notorious as train-busters. Check-out Zemke's Wolfpack
    Not that they weren't fast. There's a special hot-rod version called the P-47M --- hot-rod motors, more boost, water-injection, waxed-polished finishes . . . specially developed to chase down V-1s w/ top-speed =~470 mph . . . + this was NOT a small plane
