Results 1 to 10 of 11
Thread: FS: Lot of Bilstein jacks
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    0 1/70- MY72: one opening for lug wrench broken sold
    Jacks left to right
    1. 1/70- MY72 sold
    2. 2-7/72, 80€
    3. 2-7/72, 90€ (better condition than 2.)
    4. late 1975 to 1976 Green dot 100€ Sold at Strähle Swap.
    1.
    2.
    3.
    4.
    Last edited by dirk07; 11-09-2019 at 11:25 AM. Reason: All prices reduced, sold ones marked
    Are the jacks 1,2 and 3 the same as for VW Beetle ?
    Senior Member uptheorg's Avatar
    Apr 2012
    Scarsdale, New York
    I'll take the #1 69-71 unit
    PM incoming
    Jim
    __________________________________________________ ___________
    Early S Registry #2359
    1970 Porsche 911 Rally 2.4
    2018 Porsche Macan GTS
    I don't believe jack #1 is accurate for model year 69 and at least early model year 1970. The jack for these years has the lift arm at an angle to the steel shaft and has only one handle.
    911 S Registry # 1054
    1970 911 E Coupe Signal Orange (#1414)
    1979 BMW 320i
    2001 Boxster S
    2003 Audi Allroad 2.7T Tiptronic
    2014 Jetta Sportwagon TDI DSG ( sold back to Volkswagen)
    2015 Allroad 2.0 TFSI
    Apr 2016
    Stuttgart, Germany
    Hi David,
    You are correct.
    #0 and #1 are correct for MY71 and early 72( maybe for complete MY72 in the US), speaking for 911 and from 7/69 for 914.
    Senior Member Nicklasliljegren's Avatar
    Jul 2012
    Stockholm
    Dirk & David,
    I think the one lever jack was used through 69. But I’m not sure the exact date when Porsche switched to the two lever jack. But I think it was durring 1970. The 700 mile 911 S 1970 have a two lever jack. My 911 E from june 1970 have a two lever jack. I enclose two threads regarding that topic.
    http://www.early911sregistry.org/for...rect-1971-Jack
    http://www.early911sregistry.org/for...in-AB870-jacks
    The top lever of one of the jacks is cracked?
    Apr 2016
    Stuttgart, Germany
    @pergan see pictures 3+4 of #0
    Quote Originally Posted by Nicklasliljegren View Post
    Dirk & David,
    Nick and Dirk -
    This may help with cutoff date. My 1970 911E built in December of 1969 has the single lever Bilstein jack with lift bar angled downward. It appears that the transition occurred between December '69 and June '70.
    1979 BMW 320i
    2001 Boxster S
