Results 1 to 9 of 9
Thread: MY 73 A/C hose length
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Actually finalizing an A/C system. Ok, it close to winter time,.....
    Received the fifth and last hose yesterday. Unfortunatly without the fittings.
    It should be the on from the rear to the front condenser for 73 only. I don't know if it the correct length for 73 or if it is an earlier hose.
    NW10 /inner diameter close to 3/8" and its 3,57m long.
    How long should the hose part of there line connecting the two condensers for 73 be?
    Aug 2011
    Eugene, OR
    Dirk, you say '73-only. Not the same as '72 with 2-condenser system? I should have one of those for my '72 that I could measure.
    - Arne
    Apr 2016
    Stuttgart, Germany
    As far as I know the routing of there hoses were changed slightly from 72 to 73.
    Aug 2011
    Eugene, OR
    My copy of the parts book shows the same part number on that hose from '70-73 - 911.573.153.00
    I should be able to find mine and measure it if that would be helpful. It's in a box somewhere.
    - Arne
    Apr 2016
    Stuttgart, Germany
    Thanks Arne, would be very helpfull.
    Will have to check the correct length before I ll send out to crimp the conectors to the hose.
    Why not by the wrong hose and crimp yourself? remember that the orientation of the fittings has to be correct too. Or, buy the hose and fitting do a dry fit to clock the hoses properly and then have them crimped.
    Apr 2016
    Stuttgart, Germany
    I will never fill the AC and use only old original parts for missing ones on this car.
    The hose was installed for several decades and is in the correct form so that we now the angle to mount the fittings correctly.
    Aug 2011
    Eugene, OR
    Quote Originally Posted by dirk07 View Post
    OK, stand by. I'll get that hose out of storage later today.
    - Arne
    Apr 2016
    Stuttgart, Germany
    So is 3,57m long enough?
