Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: 1971 911S seats (tilt & sliders)... not fitting
    1971 911S SPORT SEATS (tilt & sliders)... not fitting
    Hi Guys! I know this should be super simple.... but somethings not adding up.
    I've got a 1971 that I'm putting sport seat into.
    1). Attached is a photo of the black mounts (that are bolted to my floor) to accept the seats with the tilt & sliding mechanisms.
    2). Attached is a photo of the tilt & slider assembly.
    Why will my seat sliders not bolt up to the black mounts that are bolted to my floor?
    FYI: When the tilt & slider mechanism is bolted to the seat, and I place the seat into the car and onto the black mount (that is bolted to the floor) my slider mechanism is slightly too wide to match up to the floor mounts (by about 1/2 inch).
    ALSO... when I attempt to bolt my seat sliders to the floor mounting bracket, the slider on my seats are pretty short, compared to my black floor mounting brackets. The holes don't line up, to bolt the the slider to the floor mounting bracket.
    WHAT AM I DOING WRONG? ;o) Does anyone have pictures of how things should look? Do I have the wrong tilt/sliders for my '71?
    Do I have the wrong floor mounting brackets?
    I think you are trying to put seats for a G bodied 911(74 and later) into a F bodied car (69 thru 73) car. You need a pair or very simple adaptors like the ones in my car. Once you get them installed correctly, don’t let your passengers spill coffee on your brand new seats, though.
    Dec 2015
    NE Michigan
    Is that where the term " Cars and Coffee" came from?
    Apr 2004
    35,000 ft
    that tilt mechanism doesn't look like anything I've seen fitted in a Porsche before, between the hydraulic lift strut, to the toothed slider lock, it just seems wrong.
    Show us the seats that are going in.
    often, a pair of sliders is al you need, but as Jim said, sometimes a set of brackets will do the trick. In the past I had a set of wedge engineering brackets that worked
    https://wedgebrackets.com/porsche-91...-brackets.html
    but there are plenty of others....a local race shop might help, and some standard sliders, or those from a slightly later car, depending on what the seats are
    https://www.plantedtechnology.com/pl...eft-right.html
    here's a set of wedge brackets and sliders that might help
    http://forums.pelicanparts.com/porsc...ompressor.html
    and these sliders are what I've used most often when fitting various seats in various cars
    http://forums.pelicanparts.com/porsc...t-bracket.html
    Senior Member VintageExcellen's Avatar
    Feb 2007
    San Diego
    Please post more pictures of the home made junkyard joe tilts you have as I would like to give the builder an award for amazing effort but also an award for not giving up when clearly he should have gave up. Those can’t remotely be called sport seat parts and I would never put anything like that in an S. Did you get a really good deal? Totally home made brackets and poorly made too, that’s why it doesn’t fit.
    Wow. Wasn't expecting that last comment.
    I guess it would have made it easier if I would have also posted a few photos of the seats, yesterday.
    So you could get a look at the seats... not just the slider/tilt mechanism.
    There's what the seats look like with it removed.
    THIS SHORT VIDEO.... might show things MUCH better.
    https://youtu.be/piIU0XVmqd8
    I removed the slider from the tilting bracket... which no doubt, did not belong on the tilting bracket.
    It was not a Porsche slider.
    *Anybody have nice phots of their seats out of the car?
    A few photos with tilt assembly on the bottom of the seats.
