Results 1 to 7 of 7
Thread: 67-68 911S/L rear caliper bolts
    Sep 2007
    Norway
    Does anyone have the 10x28mm bolts to mount rear caliper for vented discs on SWB?
    '67 911S Sunroof, Polo Red(Project disguised as a G-model)
    '67 912 Sunroof, Light Ivory(Alive and kickin')
    '67 912 SWTarga, Signal Red(Project in the making)
    X: 67 911 Coupe + 67S Targa, 912, 924, 944, 928, 356
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by 91167coupe View Post
    since most cars i broke where 912 (10x25)i`m not to positive ..but i`ll have a look
    Aug 2009
    SF Bay Area
    There are spacers that are needed, too before bolting the calipers to the trailing arms. That's why the bolts are a bit longer.
    Jim
    PET '65-'69 911 Fig. 6-03-00, #(10) 900.074.120.01 Hexagon-head bolt, M10x28 (for Vented rotors) Qty: 4
    The Porsche supersession, 900.075.111.08 is M10x30 (2mm longer) PCNA List 2019: $2.64
    If you can live with a competitor's part:
    BMW 1502-2002tii Fig 33/11, No.09, Part #: 07-11-9-913-836 Hex bolt, M10x28, Differential-housing/housing cover, $0.63
    May 2013
    AUSTRIA (tu felix)
    have them...verbus 8.8, and verbus 8G ,karro 8.8 and a few kamax 8.8
    Sep 2007
    Norway
    Thats great!! I think I have Kamax bolts, will double check! And I have the spacers (aftermarket).
    Btw Whats the correct hub for vented discs on front on SWB(67)? I have both 40mm (original 67 912) hubs and the ca 47mm hubs. I have 3" calipers for vented discs and I have ordered SC discs.
    Sep 2007
    Norway
    I have Kamax bolts so perfect if I can buy 4 of the 10x28 Kamax with washers of you!
    Btw, do you have a pair of 356C/912 rocker bridge complete? And a bad/damaged original steering wheel (I will use the hub for a Nardi wheel).
