Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Product Review - Sierra Madre (Dansk?) Lightweight Taillight Assebly Set
  1. #11
    Quote Originally Posted by Arne View Post
    I just noticed that one of my 2 reviews did finally post today.
    Can you make a picture of the two housing (OEM and plastic) together to compare them and try to understand where the differences are.
    Maybe it is the new gasket too hard to let a perfect fitting lens and body.
  2. #12
    The difference is metal vs. plastic. Plastic will not hold it's rigidity.
    62S-R-S, If you attempt to cobb up some type of bracing system, then the assembly will not slide into the opening for the light housing. As I remember the plastic housings were the same price as the real deal. Why would you want to spend several hundred dollars on a new part and then spend time to try to make it work.
    Most people on this board , like myself are those who seek to always use original parts as the car was delivered.
  3. #13
    Forgot to mention, look at the wiring loom coming out the back side of the housing. K Mart style, not Porsche.
  4. #14
    Aug 2011
    Eugene, OR
    Quote Originally Posted by italux View Post
    Sorry, no. The plastic housings were returned several weeks ago.
    - Arne
  5. #15
    Nov 2009
    Cecil pa
    Quote Originally Posted by Rick Cabell View Post
    Metal is the preferred material. I had the impression plastic housings were a fun friendly price of $79 ea. vs. original. Aase lists SWB housings > @$1500. Unless you make your own parts, there is no way to have moderate level pricing nowadays.
  6. #16
    Senior Member Fubawu's Avatar
    May 2013
    I have plastic in my race cars. Fit is very good not perfect but well worth the weight loss.
    I'd put it in a street car as it saves close to 5lbs
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  7. #17
    has anybody tried the ones from Design 911 in the UK ?
  8. #18
    Aug 2011
    Eugene, OR
    Yes, the wiring is rather cheesy, but wiring is not that hard to correct and rework.
    Quote Originally Posted by Fubawu View Post
    I think these would have been fine for a race car. For my purposes with my street car, 5 lbs. (2.2 kg) is immaterial, and not at all worth the poor fit. There would have been no way to keep dirt and moisture out of these housings, given that I do drive in the rain, and the lens-to-housing fit was so bad.
    Quote Originally Posted by zundfolge View Post
    I have not, nor have I seen any of those here in the US.
    - Arne
