Results 1 to 10 of 16
Thread: Charcoal canister vs windshield washer tank
    Hi all,
    I'm trying to restore a '70 911E. When I purchased the car, the windshield washer tank and charcoal canister was missing. After finding the pieces and go to install them, they charcoal canister hits the windshield washer tank. If I rotate it 90 degrees, the hoses would hit the battery. Can some tell me what is wrong with this setup. The other threaded hole pictured is for the battery strap (I think).
    Chris
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Looks like the car had a front crash and the battery holder/tank Support was replaced with a later 74-89 repair panel
    I think you are correct. When I was repairing some of the sheet metal, it appeared that the panel was new. So is the connection for the charcoal canister the only one that is incorrect or are there other differences?
    Chris
    Chris
    Please send more photos of sheet metal in front area for review
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    May 2006
    CT
    Hi Chris
    This photo shows the location of the canister relative to the battery and the washer reservoir on my '70E
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Lightbulb
    And from my '73.....
    So I don't know if this help any. Here is a photo that I took without the bracket. I'll get more when I get back to the house.
    Oct 2010
    Southern Ca.
    You need to find a car and measure the correct hole location for the canister bracket or have someone take a picture with measurements , the hole you are using is incorrect .
    May 2006
    CT
    Here are a couple of pics showing the hole location.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Member AKAMick's Avatar
    Sep 2018
    77°50′47″S 166°40′06″E
    The top is a Dansk replacement panel (incorrect for 70), the bottom is the Restoration design panel (correct), the orange piece is the best part of my old panel, 70T, note bolt locations. Name:  100_2589.jpg
    Current fleet, mostly rubbish automobiles and other assorted junk.
