Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Porsche 911 Pinion Shaft and Ring Gear Question
    Restoration newbie.
    Jun 2007
    San Francisco
    Quote Originally Posted by denniso View Post
    Hi Jon,
    Thanks for the pictures. They definitely help to identify the different pinion shafts. I don't have the factory Tech Specs booklet, but I do have the factory 911 workshop Manuals. Hopefully that will have the info.
    Thanks for the help.
    Dennis
    Section R. P.23. If you don't have the replacement page with the 70+ info post back here and I will dig it out.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Apr 2013
    Clayton, NC
    Hi All,
    I would like to have the Matra Dial Indicator Gauge that came with my VW385 kit for setting/checking pinion gear depth cleaned and calibrated. I bought this kit from the son of the deceased owner, so he didn't know the history of the gauge. Does anyone know a shop that will check, clean and calibrate these gauges?
    Also, the Factory manual specifies a 0-3mm gauge for use with the VW385 tool. My Matra gauge has a 0-10mm range with 0.01mm accuracy. Is this gauge acceptable, or do I need to find a 0-3mm gauge? If so, does anyone have recommendation on an accurate gauge that will work with the VW385 tool?
    Thanks in advance.
    -Dennis
    Dennis, a 0-10 mm indicator might be too large and long to work in a VW385, but I haven't tried it.
    Any quality 0-3 or 0-5 mm indicator should be fine. Here's an old 0-5 mm Zelenda in use...
    Jon B.
    Vista, CA
    Quote Originally Posted by Jon B View Post
    I'll re-phrase that to say almost any, because I'm sure there are some with non-standard features.
    The indicator should have an 8 mm mounting post that's roughly 15 mm long. The standard dial will be roughly 40 mm or 1.5" in diameter.
    Jon B.
    Vista, CA
    Senior Member Orbit's Avatar
    Jupiter , Florida
    I tried buying the pinion depth shims at the first of the year from Porsche and they only had .20mm shim I believe. They come in .10, .15, and .20mm - the metal shims on pinion shaft to set pinion depth, did you have a source.
    Rodger@orbitracing.com
    Apr 2013
    Clayton, NC
    Hi Jon,
    Thanks for the response.
    Can you clarify what you mean by mounting post? The Matra will physically fit inside the VW385 tool and can be clamped in.
    Hi Rodger,
    I have not tried to buy any yet. Sorry.
    Dennis
    Dennis, have you tried setting the tool up with your Matra indicator?
    Do you have a VW385/30 master gauge to set your tool?
    Jon B.
    Vista, CA
    I use a Mitutoyo 0-5, .01mm. Small dial that a side cover with seal will fit over. G
    Apr 2013
    Clayton, NC
    Hi Jon,
    I have not tried to setup the tool yet. I should have time over the upcoming holiday to try. Yes, the kit I purchased came with a VW385/30 master gauge.
    Hi Gled,
    Thanks for the picture and info. I'll definitely look into that one.
    Dennis
