Thread: FS: 1971 restored Pedal Assembly
    Dec 2009
    Copenhagen, Denmark
    For sale: 1971 911 pedal assembly. Stripped, primed and painted. No rust. Many new parts. Works as new. $325.
    James Hurst #1638
    R Gruppe #514
    May 2006
    Riverside CA 92505
    The upper clutch pedal appears to be from a 914 with the bend near the threaded end. If it is a 914 pedal it will hit the fender well. It also need a washer on the accelerator shaft to prevent lateral movement. Note the gap between the crank and the housing.
    Dec 2009
    Copenhagen, Denmark
    Good catch. I debated the washer as I didn't want to impede accelerator travel. I will reinstall. This clutch pedal came from a vendor and I will ask them for the correct pedal.
    James Hurst #1638
    R Gruppe #514
