Results 1 to 10 of 13
Thread: RS plastic fuel tank front bracket info?
    I have bought a plastic RS tank (thanks Tom), and received the 3 mounting brackets with it.
    Does anyone have detailed pictures of the front bracket setup? It is rather intuitive, but why not make it factory correct?
    Is your car a 73? If not front mounting might not be there.
    It isn't there (69), which is why I am asking for reference pictures.
    I’m not around my car now but the front mounting bracket is so far under the front of the tank it is bolted from under the front end into the threaded bracket. I’ll try and get a pic later.
    Looking forward to them. Many thanks.
    Here u go. My Italian 73.
    Verrrry good, many thanks.
    George, does the 69 have the upper riveted nut plate for brackets. G
    No, but I knew the details of those.
    Think Jimmy T made them some time back
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
