I have reorganized my posting of early Porsche parts upon popular request and have several new offerings. Contact me if you see something you want or even if you are interested in a related item. I probably have it. I am selling the following now:
1. (10)3-pin CDI units 12 MO warantee-$425, with rebuildable exchange-$275.
2. (5) Weltmeister-or equivalent gated short shifters-Porsche body(05 or 06) and custom Seine gate-$350. Add $55 for knob alone and $19 for new boot. Shifter alone $250.
3. (4) Complete Carrera cooler kit with SPAL fan ($865) -(good shock mounts, short oil lines, relay with wiring, and mounting hrdwr). Terbarol oil cooler($250). Complete B&B oil cooler kit as above $1075. Flexible AN16 Aeroquip oil cooler lines,thermostat and fittings($650)-complete front to back setup. Oil plate cooler kits-$250.
4. Mocal Oil Thermostat AOT2 -$125. AN12 fittings for Mocal-$20, SC/Carrera Oil
Thermostat-911.107.163.OR (good threads)-$250.
5. 1970-2 911 rubber oil Lines and fittings(inquire)
6. (1)180 MPH (mechanical) Carrera rebuilt speedo-$650.
(1)2.2L 911E (70/71) $8500-$10500 Mag. Stacks/Throttle bodies etc and MFI and fuel pump
(1)2.2L 911S (70/71) $10500-$12500 Mag. Stacks/Throttle bodies etc and MFI and fuel pump
(1)2.0L 911E (69) $8500-$10500 Mag. Stacks/Throttle bodies etc and MFI and fuel pump
(2) 2.4L 911E (72/73) (inquire) Plastic Stacks/Throttle bodies no MFI pump
(10)2.4L 911T (72/73) $6500-$8500 Plastic stacks and MFI pump and fuel pump
8. PARTIAL MFI SYSTEMS OR PARTS eg.-injectors(6 untested $375 or
Tested $500), fuel consoles $550, MFI fuel pumps rebuilt $250-450, air boxes-$550, 1972/3 2.4L 911E stacks and throttle bodies-$3000. Mint 2.4L 911S throttle bodies-$1800.
9. (3)1972 911S oil console-$575, (5)1972 911T oil console-$425.
10. Volvo Turbo fuel pump/regulated for MFI applications(3 port direct substitute forBosch 001)-pressure and flow tested-$350 see #2 Posting for more
Old 12-20-2019, 11:14 AM
