Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 46
Thread: Hot 2 liter engines
  1. #11
    Jun 2010
    Garden State
    Mfi-Name:  69 911S HP.png
  2. #12
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Quote Originally Posted by G69 View Post
    That document is PoA specific and was in response to an erroneous brochure that went out overstating SAE power ratings on all models.
    190 SAE/170 DIN for 69S is correct
    1969 S Coupe #761
    Early S Registry #1624
  3. #13
    Would a 1969 S be a 2.2 anyway?
  4. #14
    Jan 2011
    Sunny Southern France
    There are quite a few differences actually!
    Here you have dyno curves for the 906 (901/20) engine
    As other stated, different valves, specific crank, specific heads, specific case ! Here you can see there's an additional closing bot on the 906 case (picture from Porsport)
    Plenty of specific bits on a 906 engine. And as said before, it must be a peaky engin to drive on the streets...
    Olivier.
  5. #15
    Aug 2009
    Atlanta
    Quote Originally Posted by Schläfer View Post
    The model year 1969 cars were 2.0 liters. 2.2 started for 1970 model year.
    The pistons, valves, and ports in a 69S are as close as you will get to a 906 power/torque delivery for the street and are a one year only setup.
    Refer back to the chart I posted earlier that shows the differences between a 67-68 Weber S and the 69S
    1969 S Coupe #761
  6. #16
    Restoration newbie.
    Jun 2007
    San Francisco
    906 pistons look almost like 69s. Maybe higher compression again. Important difference: only 2 rings per piston.
    There's pictures on this board somewhere.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
  7. #17
    Restoration newbie.
    Jun 2007
    San Francisco
    Actually looks like there are 2 and 3 ring versions. http://www.early911sregistry.org/for...67-68S-69S-906
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
  8. #18
    I remember someone posted here about a factory hot 2.0 that was streetable because it had S size ports.
  9. #19
    I've got most of one of the last seasons 2 litre cup motors, which will be built into my 66 motor. When the rules changed to enforce small valves, I bought the whole of the now outlawed top end. It's a large valve head from a 69S (11/68 - 2/69 casting dates though). I don't want to give too much away as I'll start a separate thread, but I've seen the car which the engine came from road tested, and it is mind blowing. It idles nicely and has (relatively) polite manners.
  10. #20
    Nov 2003
    Santa Monica CA
    why was the small valve rule changed?
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
