Results 1 to 10 of 11
Thread: Is dowel pinning of 2.7 RS engine case necessary?
    Senior Member Einar Irgens's Avatar
    Dec 2009
    Tromsų, Norway
    According to How to modify and rebuild your Porsche 911 engine, racing engines where more than 250 HP is anticipated should have dovel pinning to reduce flex. Some say that this modification should be made in any engine rebuild, also on engines with "normal" output. Any thoughts about this? I am having built a 2.7 RS clone engine for my 1973 911E targa. If dovel pinning is to be carried out, the case has to be shipped abroad, which will be fairly expensive.
    Einar Irgens
    Norway
    I'd have it align bored at a minimum. Dowel pinning isn't really necessary because producing 250 hp out of a standard compression 2.7 isn't likely.
    Early S Registry #235
    rgruppe #111
    I think honing the main bearing bores to std. is in order if the bearings are tight when torqueing the case. The bearing bore sometimes gets smaller rather than larger. Ive found this to be more of a problem with hot running 2.7 motors, not so much for 2.0-2.4 mag cases. Line boring and oversize bearings are expensive.
    The necessity of dowel pins or anti-shuffle pins is more related to RPM . I have seen 2.7's run at high RPM (5,500 ) with wear at the main bearing journal case half because of movement .
    Also more of a problem in the 2.7 because of the longer stroke .
    Dec 2009
    Tromsų, Norway
    Thanks, all of you. Still not sure what I will do, though :-/
    Jan 2007
    Phoenix, AZ
    I'm pretty sure there is a machine shop in Europe that can shuffle pin a case, it isn't rocket science, just exact measuring. How are the bores now? Does it need a line hone too? Personally, I would shuffle pin the case if it is going to be enjoyed.
    It's a "while you're in there" sort of thing. No second chances if you change your mind.
    http://olliesmachine.com/uploads/oll...March_2019.pdf
    rgruppe #111
    and worth every penny for peace of mind
    Senior Member majordad's Avatar
    Dec 2012
    Cork , Ireland
    I did not have it done on my 2.4S restoration, the shop said no real need. After 2000 miles the engine tightened so we had to do it.
    Just do it !
    Dec 2009
    Tromsų, Norway
    Quote Originally Posted by majordad View Post
    Just do it !
    I will!
    The engine case seems to be in very good condition, so I concidered omitting any machining, but from what I am told, the magnesium no matter what will loose shape after years of shifting temperatures. Better to do i properly and avoid having to tear down the engine again prematurely.
