Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Can anyone measure size of a 68 coupe sunvisors please ?
    Aug 2012
    France
    Hi,
    back on that one
    Can anyone measure the length and height of a 1968 SWB coupé sunvisor please (guess same driver and passenger) ?
    I believe I have Targa ones in my coupé.
    thanks
    Xavier
    O-G 26 - Early911S 2407
    Junior Member
    Sep 2012
    Boulder, CO
    I can later today if someone doesn't reply sooner.
    Aug 2012
    France
    Bump for the request
    Aug 2011
    Australia
    longest length 465mm, height 150mm
    S Registry#2021
    Aug 2012
    France
    Quote Originally Posted by mrar View Post
    Thank you, will go compare.
    As you probably know 68 visors have a specific form due to the central rear mirror.
    If you are not far from Paris I can lend you one to compare.
    Cheers
    Bruno
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Xavier PJB View Post
    Hi,
    back on that one
    thanks
    Xavier
    You can't have Targa sunvisors in your Coupe, well , anything is possible I suppose. Targa visors have pivots on both ends, only rotate up and down and are black on both sides. Your 68 Coupe visors are black on the top and white on the bottom and have only 1 pivot from the outer end and rotate up and down and also side to side. 68s do have a unique shape, as mentioned earlier and are "one year only". There are discussions of sun visors and many pictures also in previous threads on this forum.
    Jim
    Aug 2009
    SF Bay Area
    Actually, I just stumbled on a 68 Coupe sun visor. I put it next to a 69 and later visor and the difference is obvious. The 69 visor is a bit longer, too. The 68 visor is the one on the top, by the way
    Jim
    Aug 2011
    Australia
    Xavier,
    I should of included a pic.
    My 68 is early build (8/67) with hangover 67 features.
    S Registry#2021
    Aug 2012
    France
    Mystery solved ! thanks to all and kudos to Jim. I have 69 sunvisors in my 68 coupé.
    When I pull down the sunvisor, it is masking partuially the central mirror because this side part of the sunvisor is too large(height).
    Now I have a pair of good 69 sunvisors for sale or swap from to 68 ones (or buy)
    Cheers.
