Thread: Valve question
    Feb 2012
    Netherlands, Leiden
    Valve question
    I have a set of 64 and a set of 65 heads. All but three have the valves. I bought a couple to complete the heads, but I think I bought the wrong ones.
    Exhaust valves seem to have a 38mm diameter and AUS KO P82 stamp, and the intake valves have a 34mm diameter.
    What should be the original specification for a intake- and exhaust valve on a 64/65 head?
    According to this thread exhaust valves shoud be 35mm?
    Einlaß 39 mm
    Auslaß 35 mm
    Jon B.
    Vista, CA
    Feb 2012
    Netherlands, Leiden
    Thanks Jon! Any idea what valves I have bought?
    Jesse, I can't think of any Porsche engine with a 34 mm intake valve. Even 356 with 1600 cc engines had 38 mm intake valves.
    A 38 mm exhaust valve was used in various Porsche engines from 1967-1972, including 911T, E, S and 914/6.
    Jon B.
    Vista, CA
    Feb 2012
    Netherlands, Leiden
    Ok thanks!
    I will look for the correct valves ����
    Aug 2011
    New York
    Here's a chart if it helps.
    E Sully
    1973.5 911T
