Results 1 to 10 of 20
Thread: front license plate mounting, best method
    May 2014
    South East USA
    hello,
    I was getting ready to mount my front plate. to meet the LAW.
    (blue, california 1971 plate)
    Does anyone have a great method?
    I was thinking of doing what is seen in photo...and adding the blind threaded "rivnut", and using the orig bracket. (but black, not gold)
    the mounting would make the plate at an angle...and keeps it higher the the bottom edge of the bumper. (both which i like)
    But maybe someone's got a better solution before I drill some holes.
    If you have an idea. please add photos.
    Have you considered the original factory bracket?
    +1 Wouldn't the factory bracket place it just about exactly where you're describing?
    May 2014
    South East USA
    I thought the one in the photo was the original.
    Is there another?
    Quote Originally Posted by Scott A View Post
    Is there another?
    I might be thinking of the later bracket. But the holes wouldn't match the bumper.
    https://sierramadrecollection.com/Fr...30-p17953.html
    These?....
    Peter Kane
    '72 911S Targa
    That's the one. Remember, for the most part most license brackets, like the black one you show, were dealer supplied. The one above is a genuine factory front bracket. The rear brackets were totally up to the dealers and were locally sourced. I know, I was putting them on in the seventies.
    Senior Member karlusmagnus's Avatar
    Aug 2005
    NY
    alternatively ... what you do is get 3m Paint Protection Film installed in the area where you will get mount or tape the license. Use VHB tape (super strong for outdoor use) to attach plate to 3M film. When you want to remove just pull off the film and you will be done. Q.E.D.
    '72T Coupe - Sepia Brown
    Jan 2019
    SF Bay Area
    another option is to use neodymium magnets. one set of magnets gets epoxied behind the bumper, then you sandwich (and epoxy in place) matching magnets on the bracket to hold it in place. the license plate then just gets mounted to the bracket as usual.
    it's worth putting a piece of adhesive-backed rubber or paint protection film on the 'back' side of that bracket to protect your paint as well. this type of setup is strong enough to keep the plate mounted on the car while driving but very easy to remove anytime. I've had a setup like this on one of my other cars for years.
    Member #3857
    '70 911 2.7
    Feb 2012
    Sweden
    Quote Originally Posted by Lz7w View Post
    Do you need the brackets or could you place the magnet straight on the license plate? (angle of plate would be different of course)
    -70 911E
    -84 3,2 Sold
