Results 1 to 2 of 2
Thread: Throttle coupler, how do determine if it needs replacement
    When the throttle rod is disconnected from the transmission linkage.The rod seems to to move quite a lot in the coupler, in a circular fashion. Not sure if it is designed to do this or its time for coupler replacement.
    Thanks for any help.
    Sounds like normal movement, it is not tight in the housing.
