Results 1 to 7 of 7
Thread: correct jack for a 70 car
    Sep 2009
    UK
    Which of these two jacks is the correct version for my 1970 car.? Would also like to know what the other is from as i would like to sell it on.
    Thanks Dave
    May 2014
    South East USA
    they looked familiar to me...so i went to take a look at mine.
    your smaller one is similar but not identical to mine.
    Sep 2009
    UK
    Thanks Scott. Both look like mine but in top shape...! I see your long version has two end caps.
    May 2014
    South East USA
    the top of the long one is rubber....which they sell as a separate part in a few places.
    Sep 2009
    UK
    Many thanks for your help.
    Dave
    Nov 2002
    San Dimas, CA
    If it's any help, PET says the part number for the jack identified as "1963 Reutter 356B T6 Cabriolet" is 644.722.010.00 and it was used through 1968 (-68). It's usually called a "Bilstein Jack" (Bilstein made/makes a bunch of different jacks) and it was introduced circa 1955 and went through several changes without a new part number--that's the final version used from '62 on. See www.356tools.com/Jack.htm In good condition its worth maybe $250 to $350.
    The rubber buffer for its top is available from Sierra Madre Collection, Aase, Stoddard, NLA Parts, etc.
    There's a much harder to find spring-steel collar thingy that retains the rubber buffer. Your pictures aren't too clear but I think yours is present. Restoring these jacks is much easier with a replacement shaft but I don't know anybody now making good shafts.
    These are often confused with early Volkswagen jacks. On a VW jack, the prong is 90° to the shaft--on a Porsche jack the prong angles down.
    Part # 914.721.010.10 was used through 1971 when it was replaced by part # 914.721.011.10. I know much less about these but the jack identified as "1971 non-Karmann 911T coupe" does indeed look like the 914 jacks I recall so I guess it could match the part number. It should be the correct choice for a '70 911.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Sep 2009
    UK
    Thanks Jim, useful information. Think i will pitch it at around $175 in it's current condition.
