Results 1 to 10 of 12
Thread: Correct wheel paint
    Correct wheel paint
    Can someone tell me which of these wheels are painted correctly? I have 4 with the wide black band and one with the narrow band. They are all deep sixes. Thanks, Mike
    1969 911S
    Senior Member jim amato's Avatar
    Feb 2011
    n.e. ohio
    wide band is correct, see the unrestored 69 for sale by rennman
    registry #2072
    Thank you Jim, better to have one wrong than four
    1969 911S
    The wheels were originally painted by dipping. This "dip" created a uniform paint line on the spokes and along the rim. If you look at the height of the paint on the spokes it should be the same along the lip. The narrow band is accurate to the original layout.
    Best regards,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Well, now that clouds the waters. I have seen a video where where someone repainted by dipping, actually they sealed off the backside and then poured paint in from the front and then breached the seal allowing the release of paint thus leaving a uniform smooth line. If the factory painted in a similar fashion then Brad is correct and the paint line on the spokes and the lip would have to be the same. Did they paint all years the same?
    1969 911S
    If you remove the center cap on one of the wheels with the deep black band, you may see black paint to the same line inside the center hole.
    In Progress
    - 1972 911T coupe, once again Silver as original
    Sold - 1984 911 Carrera coupe, Chiffon white; 1973 914 2.0, Saturn Yellow; 1984 944, Silver Metallic
    Ok, I just went and inspected the wheels a little more thoroughly. On the wheel with the narrow black band the paint on the spokes comes up much higher than on the shoulder. Clearly this wheel wasn’t dipped, leading me to believe that like Jim said the wide band is correct. Thanks guys.
    1969 911S
    Jul 2011
    Chicago Area
    Quote Originally Posted by Theunz View Post
    +1. Brad's theory was right except the narrow band does not reach the same height of the paint on the pedals and it is hard to see that in the picture that was posted. I have original deep 6's that have the wider band on them.
    Mike Fitton # 2071
    2012 991 Platinum Silver
    1971 911T Targa Bahia Red
    If you remove the tire, you will see how the wheels were dipped.
    Lightbulb
    These from a very original 9/70 built, '71E that came with 5 deep sixes...
    98 Chevy S-10 Utility
    15 GTI Commuter
Message Board Disclaimer
