Thread: Help with Frankfurt Radio for 72 911T
    Dec 2010
    San Antonio, TX
    I bought a Frankfurt radio on the ESR site some years ago to replace the radio/cassette deck "update" that had been installed by the PO. Pictures show front, mfr label and rear of the unit.
    At the time, I was too naive to request clips or necessary wiring for the Frankfurt, and now i'm ready to install the unit. Can I get guidance on proper items needed for install, plus recommendations for necessary components needed to play iPhone through the system. Further, I removed PO's door speakers when I had the interior restored, so I prefer to use Bluetooth speakers instead.
    Thanks in advance.Name:  Frankfurt side.jpg
Size:  87.0 KBName:  Frankfurt Front.jpg
Size:  89.5 KBName:  Frankfurt rear.jpg
    I'm sure someone will jump in with the appropriate mounting hardware soon. In the meantime, this will help with your bluetooth. See post # 17.
    http://www.early911sregistry.org/for...install-advice
    I would start from scratch. Sell that radio that has never been anywhere near a Porsche, especially one in the US. If you want to use that European band radio in your 911, you will need the proper faceplate, clips for mounting and the rear support bracket. The radio has value to someone in Europe or one that is restoring a ROW car in the US. You should look for a Frankfurt US monaural radio with all the proper Porsche mounting parts, IMHO.
    PS: There are dozens of threads on this forum discussing the proper radios and accessories for your car.
    Jul 2011
    Chicago Area
    This is the setup that you need.
Size:  64.3 KBName:  RadioSetup.jpg
    Mike Fitton # 2071
    2018 911S Carrera White
    Quote Originally Posted by mfitton View Post
    In my best Jedi mind trick voice, "That's not the radio setup you are looking for. Nothing to see here, move along. Wait until Arne buys his radio before you start looking."
    Yeah, I'm going to need all that as well. The only part I have in my car now is the pinch-clip support that holds the back of the radio in place. I'd be looking now as well if I didn't still have plenty of more important things to spend money on.
    Jul 2011
    Chicago Area
    Installation kit that is available.
    https://www.koenigs-klassik-radios.d...912_33152_5148
    Mike Fitton # 2071
    Thanks for that, Mike. Too bad I already bought a speaker for my car, as I wanted to have that handled before I put the dash pad in.
    Dec 2010
    San Antonio, TX
    Thanks to all for your input. Terrific info!
    Now, does anyone need a European band radio?
