Results 1 to 10 of 12
Thread: Gemini Blue....
    Dec 2013
    Connecticut/Florida
    Gemini Blue....
    My car is about to go into paint and we are rechecking the paint formula for Gemini Blue. My car was repainted many years ago, and the car is more purple than it should be. However, there is some original paint under the VIN tag. Here is a BASF Glasurit current paint compare to under the plate. We will check with Glasurit tech and see how many tint formula changes have occurred for his color since 71. In addition it would be good to find some original Porsche brochure (preferred) or paint manufacturer original chips If we can hunt down a set from Porsche circa 71 then adjust formula as needed for exact match, it would be ideal and great documentation for a job done right. What do folks think of this color compare?
    Name:  Beaumont 911 code forumla vs. good orig sample (1).jpg
    1971 911S Coupe - Gemini Blue
    We had this one a few years ago, if that helps.
    ---Adam
    Check out Unobtanium-Inc.com
    New blog posts all the time!
    Looking at the far right 'hole' and what's around it and underneath I think you're as spot on as you can be.
    Lightbulb
    Metallics photograph very differently in different light, especially blues... Ask me how I know...
    And some like to 'sweeten' the color key in editing...
    I've seen a few numbered Gemini cars painted Blue Metallic, and the other way around...
    The colors get confused until they're parked together...
    - My friend Lars' '72S on the right is Gemini Blue, my '73S on the left is Blue Metallic...
    - Second photo, same cars different light. Lars' in front...
    Hope this helps,
    cm
Size:  72.8 KB here is glasurit base coat clear coat we did a couple of years ago. Matched the original very well
    Lightbulb
    Here's a page from my '73 Samples Book...
    First pic - Indoors
    Second pic - Same page off angle in the sunlight
    Hope this helps...
    Spray out card looks a bit too green, IMHO.
    Just thinking out loud and wondering how much the original paint has darkened over 47 years...
    Peter Kane
    '72 911S Targa
    ...remember too, that even identifying a spray out card you're happy with (i.e. you consider it 'the' match you are looking for), the end result of a metallic re-spray has variables that a solid color does not (or at least not as much)...pick your painter carefully...consistency in gun distance and control, gun pressure, and mixing enough paint (same batch) will help to ensure uniformity and color match.
    May 2012
    UK
    Not sure it helps for all reasons explained and variables of camera screen but this is my colour card given to retail customers for model year 72. This is an official Porsche document from early 70s as requested.
    A friend's model year 73 car was originally Gemini Blue so happened to have ths snap to hand
    Steve
