Thread: Heater control levers are stiff
    Mar 2016
    U.K.
    Hi,
    My car was in pretty poor shape and the levers on the heater control unit didn't move previously. I cleaned the unit and it has been replaced in the car (now fully restored) but I am finding that the levers are quite stiff to move particularly the top one controlling the fan speed. Should this be so and if not, what lubrication can be applied? I remember there was a contact that slid across the top of the plate which housed the fan speed contacts. Maybe when I cleaned off the dirt I also removed lubricant?
    Gitesh
    more than likely dry or damaged inner cables trying to slide within the outer cable. try to squirt lube in from the exposed ends and work cable its full travel,,,,might improve it. It won't be from sliding contact.
    The levers are connected to cables that effect the movement of blender doors (flaps) associated with the fresh air inlet box. This is located in the front trunk behind the cardboard bulkhead liner. You can disconnect the cables from the blender doors to see where the resistance lies.
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    I had the same problem. The eventual cure was to replace the cables...not easy, but certainly doable if you have basis skills.
    Alan
    N.J.
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
    Apr 2011
    N.Calif., south of SF
    Gitesh what year?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Mar 2016
    U.K.
    Thank you all for replies. I’ll take a look and report back.
    Haasman, it is a 1973 car.
